Is it possible to change the old '83 pop up lights to new prelude lights that arnt pop up?
Fitting them between the chrome stip around the front where the dark grey shaped bits are?
from these lights:
Fitting these lights in:
						Remoddling headlights?
				clarky92
 - Prelude Model: 1983/twin carb et
Re: Remoddling headlights?
There was a model of the 3rd gen prelude that came without pop-up lights. I believe it was called the INX. Getting a pair of lights from an INX prelude would likely be the easiest way to incorporate sealed beams into a 2nd gen as they will be roughly the same size.
Lights from a similar year Integra may also work.
Whichever way you go though, there will be a lot of custom fabrication required.
