Are short ram air intakes a good thing to install ?... I was looking into it for my 2000 Prelude and as you know there are always negative things to be said about almost every topic....One negative aspect of short air intakes, is they may screw around w/ the mass airflow sensor and cause the temperature of the car to rise. Also I read that because the air is a higher temperature, the result may be a loss of some power....Also, the car may run lean which can eventually cause engine failure....Given all this, what are your thoughts on short ram intakes?
Thanks again for your valued opinion
Mitch
short ram intakes
Re: short ram intakes
Personally, I'm not a huge fan of 'short ram' intakes. They draw air from the back of the engine, which isn't a very fresh supply. If you're going to put an aftermarket intake system on your car, you want it to draw colder fresh air. The longer tubed cold air systems are a better option and can give you a few extra HP. Companies like AEM make great cold air systems that pipe air from areas of the engine bay where there is a fresh supply of cold air.
