rear view mirror
jasong719
rear view mirror
how do you replace the rear view mirror? I knocked mine off and need to replace it?
jasong719
rear view mirror
yeah ,there is a slot that it slides into. how do you get the light off and too it?
Jason,
Remove the lens from the light. (pop out with a flat head screwdriver)
Remove the two bolts from inside the light itself, this releases the light fixture. There is a wire connector that you can unplug or leave in. Easier to just unplug and get the whole light out of your way.
Once the light is out you have to remove the light trim piece.
Then there are two clips (facing the windshield) that have to be popped and the back of the trim has three small hooks, using a forward and down motion, this should get the trim piece off.
You should now see the mount for the mirror. Remove the three screws and the rubber damper and remove the mirror.
I've got the visuals linked below:
Good luck!
~ Josh
Good luck!
~ Josh
