cquence rotors install
91darkness
Prelude Guru
Post by 91darkness »
hey guys i have some new cequence rotors. eBay $89 shipped. Takes about 2weeks, but its worth it. They make any style you want and they have many styles. cquence.net is the actual website. The install was pretty easy. I had some PB blaster on hand, which takes care of rusted on bolts. While removing the two bolts that hold the caliper to the mount, i sprayed the two screws that bolt down the face of the rotor. (they secure the rotor to the hub). Then i removed the two bolts that hold the mount to the knuckle. After removing the two screws that lock the rotor to the hub, i had to knock the rotor on one side to loosen it up off the hub. Before you re-install the rotors be sure to press in the caliper piston.
Just repeat the process backward.
Re: cquence rotors install
Those look great.
Nice pics of the install.
How does the car feel now?
91darkness
Prelude Guru
definitely no shaking or vibration when i stop now. They feel pretty good, but until i replace the ABS system it wont feel the way i want it too.
