cquence rotors install
Posted: Fri Dec 24, 2010 7:29 pm
hey guys i have some new cequence rotors. eBay $89 shipped. Takes about 2weeks, but its worth it. They make any style you want and they have many styles. cquence.net is the actual website. The install was pretty easy. I had some PB blaster on hand, which takes care of rusted on bolts. While removing the two bolts that hold the caliper to the mount, i sprayed the two screws that bolt down the face of the rotor. (they secure the rotor to the hub). Then i removed the two bolts that hold the mount to the knuckle. After removing the two screws that lock the rotor to the hub, i had to knock the rotor on one side to loosen it up off the hub. Before you re-install the rotors be sure to press in the caliper piston.
Just repeat the process backward.
