Rear Toe Adjustable on 01 Prelude?
Posted: Tue Jun 23, 2009 10:04 am
				Hello all, I'm new to this site but have a couple questions already for my 01 Prelude SE!  After taking off my summer set of tires and putting on my winters, I noticed the summer pair treadwear on the rear looked very scary. (both tires)  Extreme inside wear and the belt was poking through already on the rear right.  The fronts were fine.  After taking it in for a 4-Whl alignment, they said that toe should read between 0" and 0.08" , but right rear toe measured 0.18".  Then they told me because of vehicle design, Rear Toe can not be adjusted... simple as that!  So what do I do!?  I thought I'd go to another garage - this time a big name one specializing in muffler and suspension.  I showed them the Diagnostic printout, and they said of course it can be adjusted (rear toe).  - So who do I believe, and how do I find out whats wrong on the rear end... I want to get those Falkens off ASAP - because they are pretty soft rubber and I was impressed with them over the winter and don't want uneven wear either.
Also, I noticed last couple of weeks, strange chirping noise coming from under hood or near there (Dash maybe?). This is when Its in neutral. When I depress clutch about .25 to .5 inch down, it disappears... Is this somethin serious, or do I just need to buy some silicone lube spray and crawl underneathe the dash and spray the clutch cable?
