Ok I saw the power steering fluid was low because the belt kept on making noise and I put fulid and the noise is still there..
Can anyone help?
Power steering ....HELP
Re: Power steering ....HELP
If the belt is making noise it's probably because it isn't tensioned enough. There are bolts and a tensioner on the power steering pump that can be used to tighten up the belt. See the service manual for information about how tight the belt should be. DO THIS WITH THE ENGINE OFF! Spinning engine belts will easily take off a hand. Never work on them while the engine is running.
