head swap complete
head swap complete
well i finnaly got my car running again. Still not sure on what the problem was but it runs finnaly. But i still have a coolant leak somewhere. When i fill the car with water it leaks out somewhere near the back of the motor. Im hoping its just a disconnected hose somewhere but it could be worse.
Re: head swap complete
Find the leak. Since you had everything apart you've probably just got a bad hose seal somewhere. Easy fix. Glad to hear you got it all together.
Hi , can you tell me what heads you replaced and if you think your horse power increased? I'm wanting to do a head swap also. need some more HP from my B20 A5 1988. Good luck with the car.
Trev
Trev
