How much will new clutch be?
I know the clutch on my 'lude works great I barely have to use any pedal travel at all to shift gears. I am very easy on clutches and there are no hills here at all. My question is how much will the clutch cost to get replaced when it goes? With 200K on that car, that clutch will go at some point.
Re: How much will new clutch be?
Should be around $130 or so if you get aftermarket. $200 from Honda.
These prices are for both the pressure plate and the clutch disc.
Just curious though, are you referring to the cost of parts, or the cost of parts AND installation?
If you go w/Honda parts and have a mechanic do it, you're looking at least $600+ in most cases. Just my 2 cents. A good clutch install doesn't come cheap when you pay someone else to do it and when you use Honda parts.
